Dizzy Cap
From The Shire, Sydney
I just put an A15 into my 1200 wagon that came out of a mates 1200 ute. Problem is i need a new dizzy cap and im not sure what dizzy is in the motor coz i ordered one for an A15 but it was different, and its different to an A12 one.
An A12 dizzy cap is held on by the 2 clips, but the one on my A15 is held on by 2 screws.
Can anyone tell me what motor this dizzy came off?
Ive been to supercheap and it doesnt match any of the ones they had in stock,
Posted on: 2006/8/3 12:58
Re: Dizzy Cap
From Adelaide, Australia
Im thinking someone has used an electric E15 dissy. Is it electric or points?
Posted on: 2006/8/3 13:01
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: Dizzy Cap
its points
Posted on: 2006/8/3 13:10
Re: Dizzy Cap
From Sydney, Australia
Posted on: 2006/8/4 1:59
Re: Dizzy Cap
From Sydney
You will probably find that the dizzy came from the import 1986 C22 vanette fitted with the A15s engine. The dizzy should have been manufactured by mitsubishi. Genuine is your only option for parts. I run one of these in my A12. I beleive they are superior in design. [the base plate sits on a full bearing race.]
specs here:
Ignition data
Vanette, (C22)
Ignition system type: CB
Ignition coil make/type: Han/H5-13-49
Supply voltage: 4.1 + Volts with ballast resistor
Primary resistance: 1.2-1.4 Ohms
Secondary resistance: 8100-12300 Ohms
Distributor make/type: Mit/T4T00571
Contact breaker gap/air: 0.45-0.55 mm
Dwell angle: 49-55 Deg
Ignition Timing - unleaded: 7  2/700 Deg eng/rpm (without vacuum)
Ignition Timing - leaded: 7  2/700 Deg eng/rpm (without vacuum)
Timing mark location: Pulley
No 1 plug location: Pulley
Firing Order: 1-3-4-2
Spark plug make: NGK
Spark plug type: BPR5ES
Electrode gap: 0.8 mm
genuine Nissan part numbers are:
distributor cap: 2216 278A10
rotor button: 2215 723G15
Vacuum Advance unit: 2230 1G5710
cheers
Benny
Posted on: 2006/8/4 2:10
Re: Dizzy Cap
I ordered the A15 distributer cap for Scott from a Vanette and when it came in it was the clip on one not the screw on one. I then got the lady at super cheap to call the manufacturer and they said no A15 distributer caps were screw on.
Posted on: 2006/8/5 4:49
Re: Dizzy Cap
From Burbank, CA
E series ones were...
Posted on: 2006/8/6 18:10
|||\ 81 KPB310 /|||
Re: Dizzy Cap
Thanks benny
I ordered the cap and rotor button from the nissan dealership today he said he couldnt ring up first to make sure it was screw on Hoping its the right one!!!
Posted on: 2006/8/7 0:23
Re: Dizzy Cap
Got my new dizzy cap and button from nissan today and glad to say it was the right one.
Big thanx to Benny for the part number or id still be looking for one.
The car runs 100% better now, ready to kick some ass around Wakefield
Posted on: 2006/8/9 13:04
Re: Dizzy Cap
From Sydney
oh no
or at least you might make it there now
Posted on: 2006/8/9 14:52
