a12 gx motor
From Darwin NT
does any body know if this is an actual gx motor?? im thinking of getting it but dont know if its really a gx motor
Posted on: 2006/8/13 23:13
Re: a12 gx motor
It's not possible to tell from the photo that he has provided.
Posted on: 2006/8/14 4:06
Love your Datsun.
Treat it well.
Re: a12 gx motor
From Portugal
They look all the same from the outside...
Posted on: 2006/8/16 13:30
Re: a12 gx motor
From Bunbury Western Australia
My last A12GX engine had the distributor at the back but that one has the distributor up at the front which leads me to think it is an A12 with an A14 or A15 head sitting on top. I don't think that the A12GX ever had the distributor at the front but I have been wrong before!
Posted on: 2006/8/16 14:48
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Re: a12 gx motor
From Adelaide, Australia
Blofly i would of thought that a B110 A12 GX motor would have the dizzy up front. A 120y A12 GX motor would have the dizzy beside no. 3 as with any later model a-series.
Posted on: 2006/8/16 15:08
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: a12 gx motor
Tell the seller to pop the rocker cover, and take close up pictures of the cylinder head. the gx heads should have two little humps just above the intake ports. the block should be an early style with the distributor up front. There are pictures of the gx motor on the forum.
Posted on: 2006/8/17 0:39
Re: a12 gx motor
From Portland OR. USA
If the seller agrees to pull the valve cover, also look for double valve springs.
Quick summary: A A12GX should have large oval ports and dual valve springs.
It makes me wonder about the claims of being a GX motor when they don't show the port side of the head...
Gary
Posted on: 2006/8/17 1:42
