changing diff oil?
From Brisvegas, oz
just wondering if you need a special tool or somthing to remove the drain plug it looks like it need some type of square shaped allen key.
Posted on: 2006/9/7 3:37
www.camerasplus.com.au
Re: changing diff oil?
From Melbourne, Aus
try the half inch drive on your ratchet
Posted on: 2006/9/7 3:43
From Mie Japan
Spiner Hendel or BOX wrench is handled.
12.7mm
Let's try.
Posted on: 2006/9/7 3:47
Not too shy to talk
From wyong
i just checked my diff oil level in my 620 & all i used was 1/2 inch ratchet fitted straight in try it
Posted on: 2006/9/7 4:03
From Brisvegas, oz
thanks for the tip guys
Posted on: 2006/9/12 3:05
From Huntington Beach, California
Getting the fluid out is the easy part. Refilling it is the tricky part, unless you have some sort of pump.
Posted on: 2006/9/12 4:43
From Castro Valley,CA USA
Blood transfusion I hope this helps getting the oil back in.
Posted on: 2006/9/12 6:48
From SE Melbourne
I did it this way recently (with the use of a compressor) - although I think the compressor is still a pretty good idea.
Posted on: 2006/9/20 0:50
Mildman, Datsunless
From Mesa, Arizona, USA
The pressurized jar is a sweet idea! Never even thought of that. I'm going to make one this weekend. BTW, I have a CokaCola type shelf myself. Sometimes dumpster diving turns up some rare jewels!!
Posted on: 2006/9/25 18:40
turboron@hotmail.com
If it ain't broke, fix it until it is!!!
From Burbank, CA
if you can't get the drain plug out ( someone wrenched mine in ) you can siphon the oil out over night and then replace it. ( not quite as good as a real drain, but when you can't get the plug out it's better than nothing. )
Posted on: 2006/9/25 19:31
|||\ 81 KPB310 /|||
