Wats the compression for an A15
From Adelaide
hello...
i seen it on one bit.. it said 8.9... hmm wat does that mean.. i thought its meant to be in the 160 range??
cheers
Posted on: 2006/10/1 14:17
Re: Wats the compression for an A15
From south australia
when you do a compression test it should be around the 150 mark on all cylinders if it is in god condition the compresion ratio is diferent
Posted on: 2006/10/1 14:25
From SE Melbourne
Or if you want if from the workshop manual in kPa.
Compression pressure (nominal) .......... 1245 kPa
Compression pressure (minimum) ........... 980 kPa
Posted on: 2006/10/1 15:04
Mildman, Datsunless
From Adelaide
oh now i understand.. i see english.. hahahaha
i was freaked out for a sec when i seen 8.9 lol
cheers
Posted on: 2006/10/1 22:50
