120y brake calipers hitting mags or problems fitting
From melbourne
well it was just brought to my attention that the 120y brake calipers can cause a few dramas when fitting 15 inch mags,
is there anyone who would like to give us some advice on how to deal with this problem??????
i heard you can cut a part off the caliper plate ,but honestly not sure if i really want to do that as i want it to be legal and safe,
so are there any other options?????????????????????????????
spacer plates?????????????????????
custom mags???????????????????????
what mags have been used on the 120y struts with 120y calipers and how did you get them to fit ,any help and pictures would be aprecated cheers guys
evil betty
Posted on: 2006/10/6 12:07
Re: 120y brake calipers hitting mags or problems fitting
From Brisbane, Narangba
Wheres it rub? Inner face? I can only assume the wrong offset because 15s would definately clear the calipar height wise. They only had 12s standard. Ivee never had trouble with any normalish mag wheels.
Posted on: 2006/10/6 12:13
From south australia
wat rims have you got i have used 15" and 13" rims with my 120y calipers wyh out a drama
Posted on: 2006/10/6 12:15
From Brisbane Australia
is only a dramn on some rims that have a large DIA centre with no releif on them
unfortunatle that wot i got lol
Posted on: 2006/10/6 12:20
From melbourne
well i dont actualy have the wheels i want for the ute yet so im not 100 percent that i will have the problem,but it was just brought to my a ttention by john_13961
as he has the 120y calipers and saying that his 15 inch mags are having big problems with the 120y capiers with new brake pads,
i just wanted to investigate this issue for future reference as i dont really want to change my brake set up just yet
Posted on: 2006/10/6 12:23
From melbourne
ohh i see bugger,well im hoping that i dont run into the same drama as you there john!!!
so what you gona do change wheels ???or calipers
Posted on: 2006/10/6 12:24
change nothing just mod lol its a very easy task and quite save it doesnt require much to be removed at all and if u cut into the support plates top n bottom of the main one all it require is a little stich weld tooooo easy i will take some pics tommorrow for ya
Posted on: 2006/10/6 12:55
From Barranquitas, Puerto Rico
Spacers could probably help clear the calipers being that the rim will be out more but then you have to buy longer wheel studs so that the lug nuts tighten properly.
Posted on: 2006/10/6 14:46
Project R- The Real Tuner Club
