engine oil cooler.
From Sydney
Hi just wondering if any one can help me out. I have installed an engine oil cooler off a Toyota corolla AE92 (i think) and now i need the sandwich plate/adaptor that goes onto the oil filter housing/oil pump. Where can i find a decent part to do the job without causing engine damage. Thanks
Posted on: 2006/10/10 14:21
Re: engine oil cooler.
From Burbank, CA
the sammich plate is a standard hot-rod store item. I forget which thread pitch, but it's a common part.
Posted on: 2006/10/10 18:02
|||\ 81 KPB310 /|||
From Central Vic
same as early ford
Posted on: 2006/10/11 1:14
to buy or not to buy???? OK
This is the reason I have five coupes
should also be same as nissan rb engines, seeing they use the same z145a oil filters.
Posted on: 2006/10/11 11:07
From Adelaide, Australia
Apparently valiants have a remote filter assm you can use with a oil cooler!
(I Dont have a clue which model, one of those heard from a mate who knows a mate things)
Posted on: 2006/10/11 11:11
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Sydney
Yeah thanks guys, i might see if i can get one to suit a vl commodore, it will fit and i think it will be a easier for the spare part guy to find.
Posted on: 2006/10/11 15:03
From Burbank, CA
you might want to just get the oil filter relocate thing, then you can get to the filter easier.
Posted on: 2006/10/11 18:52
|||\ 81 KPB310 /|||
