A12 & A15 main caps
Are they the same or different part no.'s and strength?
Im after a set of main caps for an A15 but ive got a few sets of A12's lying around and i was just wondering if they were interchangeable...
Im guessing the A15 is stronger but you never know with clever datusn engineer's!
Cheers
Dave
Posted on: 2006/10/25 4:01
Re: A12 & A15 main caps
From Tracy ,Ca
the main caps are mated to the block during initial block machining if you don't have the orig caps the best solution is to get another block with matching caps
Posted on: 2006/10/25 6:52
From Sydney
You could use them, but I would the block/caps line bored.
Posted on: 2006/10/25 7:16
So really you cant even use main caps off say another A15s crank either? I thought that the same model would be fine...
May have to re schedual
Cheers
Dave
Posted on: 2006/10/26 12:38
From Adelaide, South Australia
You can but you will need to rebore it.
Why are you after new caps ?
Posted on: 2006/10/26 15:05
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From Melbourne Vic
you don't need to rebore the block, just the main caps to the block. Its not too expensive from memory, spewin i don't have the caps to go with it!
Posted on: 2006/10/27 1:49
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Yeah its a sh*t hey leigh... Umm i think they quoted me getting the caps & block milled about $300 but if its just the caps that shouldnt be as expensive.
Have you packed it all up yet leigh? Im ringing tasfreight as we speak to get some quotes on freight...
Cheers
Dave
Posted on: 2006/10/27 2:47
