120y diffs
hey all do 120y diffs bolt straight into 1200s coz if they do WOOHOO! if they dont tell me how i can fix that problem cheers jacob
Posted on: 2006/10/31 5:41
Re: 120y diffs
From Geelong, Vic
yes, using all the U bolts and spacers and rubber things that go round the leaves in the 120y, also you need to get the extra about 6 inch long 120y leaf and longer bolt with spacers that holds the 120y leaves together, oh and the tailshaft
i can go grab a pic of the stuff needed if i wasnt that clear
Posted on: 2006/10/31 5:58
Re: 120y diffs
if u wernt that clear lol naa good job cheers so basically i need most of a 120y rear end sweet thanks mate
Posted on: 2006/10/31 6:07
Re: 120y diffs
From Geelong, Vic
yeah if you just take the leaves diff and everything in between, you should figure it out
Posted on: 2006/10/31 6:08
Re: 120y diffs
sweet im usin it for the l series
Posted on: 2006/10/31 6:12
Re: 120y diffs
From Geelong, Vic
i was doing that, till i got a ute diff
Posted on: 2006/10/31 6:16
Re: 120y diffs
yd ya go the ute diff?
Posted on: 2006/10/31 6:20
Re: 120y diffs
From Geelong, Vic
stronger than most 120y diffs, 120y BW is the only one that is of the same strength
but for an L series conversion you want to find an auto BW diff'd 120y then the tailshaft has a chance of fitting straight up
i didnt have a 120y with a BW, so i got a ute and used its diff and got a talishaft shortened to suit, also different ratios are easier to get for ute diff, and centres are easy to get too
Posted on: 2006/10/31 6:25
Re: 120y diffs
From adelaide
im using bw h150 from 120y behind turbo l20b, no breakages yet but will upgrade to bw r31skyline later, have a welded centre though!
Posted on: 2006/11/1 12:00
1200 restoration project moving slower than it actually is
