instrument cluster conversion.
From Hobart TAS.
Hi all
Just wonderingif anyone had ay info or links on what is involved in installing the instrument cluster/ and or dash from a 180sx/s13 into a datsun 1200 dash. Main things i am unsure of, is stuff like connecting fuel gauge to standard 1200 ute fuel tank etc.
Posted on: 2006/11/4 7:17
Re: instrument cluster conversion.
From Hobart TAS.
like thisOpen in new window
Posted on: 2006/11/5 4:04
From Hobart TAS.
Or eve better. LIKE THIS! Open in new window
Posted on: 2006/11/5 4:11
From Flinders View, QLD
Hay TASDATO, I am planing on doing a similar thing as whats been done in those pics. I assume you are running a CA18 as is what i am doing. Everything should plug in to the donar car wiring harness, as for the fuel tank and gauge I am going to run a R31 tank so I will have to make sure the tank sender and gaude have the same operating OHM's, if not it wont be hard to put in a resistor to make the tank suit the gauge.
Posted on: 2006/11/5 10:48
From Hobart TAS.
cheers for the reply for BUNDY351.
let me know how you go using the r31 tank as it will still be a while before i get to this stage of the install
Posted on: 2006/11/5 11:24
From adelaide
is this legal to do?? looks good
Posted on: 2006/11/7 6:58
