help
From Rocky Queensland
does anyone have a wiring diagram or can describe how to wire up the reverse light switches from a 56A box to an A14? any help would be greatly appreciated.
Posted on: 2006/11/16 10:31
Re: help
From Adelaide, SA
What do you mean to an A14? The reverse swtich wires don't actually have anything to do with what type of motor it is.
Posted on: 2006/11/16 10:35
Re: help
From Canberra
ignition to one side of switch, other side of switch to reverse lights, reverse lights to earth... Thats basically what I did
Re: help
im not much of an auto lecki. there is 2switch like things that go into the box. both with 2wires off each. one has black wires other has yellow. where abouts are the wires in the engine bay (if there is any) and which switch is the one for the the reverse lights.... sorry if im confusing anyone. im confussed myself
Posted on: 2006/11/16 10:40
Re: help
From Tamworth , NSW
get a multimeter and set it to buzz, put one lead on each of the wires coming out of swithch, put it in reverse, if you hear a beep you got it.
Posted on: 2006/11/16 15:40
Re: help
From Canberra
or if it doesnt have a beep mode just set it on resistance, should be 0 (or close to it) in reverse and 1 when not in reverse
Posted on: 2006/11/16 15:46
Re: help
From sydney australia
the a14 boxes & later a12 boxes have a top gear switch which turns off the vaccum advance in the lower gears.this switch has spade style connectors & is the switch closer to the front of the gearbox.the reverse light switch is the one closer to the rear of the gearbox & has bullet style connectors.if you hook up the top gear switch,the reverse lights will be on all the time,except when it's in 4th gear(personal experience talking there,usually through my hat )
Posted on: 2006/11/18 3:59
Re: help
From Sydney, Australia
That's interesting about the 5th gear switch.
I'd have thought the two were neutral switch and reverse switch, both going closed circuit, when the shifter is in position.
So you could hook up the 5th speed switch to a sign in the back window that says "Hammer Time". I was going to hook up the accellerator kickdown switch to such a sign back when I was 20 or so It's an old joke at my place.
Posted on: 2006/11/18 5:42
Re: help
thanks b310gx. so its the one closest to the tailshaft that i need to hook up. but where do i hook up the bullet style switches? and so i dont worry about the switch at the front of the box?
Posted on: 2006/11/18 7:27
