Morrie engine conversion
The A series is relatively easy to fit as the Japs used the BMC motor with some modifications. Check out the Morris Down Under Forum for some useful help. Some of the changes are to the front and rear cross members. The cut down Morris engine towers are repositioned to take the 120Y engines mounts. You need to use two drivers side mounts and turn one around for the passenger side. Small section cut out of the engine bay floor pan to accomodate the oil filter and depending on the tranmission used changes to the rear mount and the floor. I have just changed from a A12 to A14 in my Morris.
[img]http://www.morrisdownunder.com/gallery/displayimage.php?album=27&pos=5[/img]
[img]http://www.morrisdownunder.com/gallery/displayimage.php?album=27&pos=6[/img]
[img]http://www.morrisdownunder.com/gallery/displayimage.php?album=27&pos=7[/img]
Good luck
Posted on: 2006/11/28 2:07
