PIGDOG wrote:
why 120y brakes, if you cant find any why not just go for wider front track and bigger brakes?
and you can make R31 rear discs fit if you try hard enough
or are you not experienced enough to tackle not bolt on stuff, not trying to offend
well i doubt my wreckers will have an R31 anyway, all they seem to have is ford or holden spares.
and i want 120y brakes and struts because theyre a good enough step up from the drummies that i have atm. if i need to i will upgrade from there later on down the track.
and as for the fact that they arent bolt in....
i guess you could say im not an experienced mechanic as this is my 1st car. but its not as though i have no idea at all.
with a welder, grinder and hammer you can achieve just about anything.
ive got access to stanza or 120y struts amd a bluebird not quite sure wat model it is but its the one with a ca20
well i'm interested in the 120y struts. do they have rotors, calipers etc with them or just struts?
as for the bluebird im not sure which model has the CA20 but i think i can use either a series 1, 2 or 3.
maybe some1 with knowledge about them can help me out.
