Browsing this Thread:
1 Anonymous Users
wtb:datsun gx head fo an a12 |
Not too shy to talk
hey all im looking for some gx heads to suit a12 engines and even gx motors send me a email and pics if you have any. cheers bill
Posted on: 2006/12/19 0:54
Re: wtb:datsun gx fo a12 |
i reckon it would be cheaper to build one then buy have a look at the tech section a bit in there covers the specs of the gx motors
Posted on: 2006/12/19 0:59
Not too shy to talk
it probably would be cheaper but gx heads work better on our racecars cheers bill ps also looking for codsworth pistons to suit a12
Posted on: 2006/12/19 1:02
a gx head consists of
heart shaped combustion chambers oval ports (like the standard A15 cylinder head). Standard A12s have smaller round ports. The best heads have the ports up higher than the round-port version. There are Oval port heads with the ports lower down. double valve springs valves. Compare to A14/A15 with 37 mm inlets & 30 mm exhaust valves Later GX heads have two little water jackets under the ports, for warming the inlet manifold intake ports shaped differently for flow and swirl and twin sus strapped to the side of it
Posted on: 2006/12/19 1:24
Re: wtb:datsun gx head fo an a12 |
ive got an a14 h72 head with oval ports,but might be too low in compression for your needs? $150
Posted on: 2006/12/19 11:12
Not too shy to talk
hey there our engines run huge compression 10:1 or 11::1 we run side draught webbers and the engine is on methanol. so i will find out if the head will suit cheers
Posted on: 2006/12/19 20:23
