alternaters
From penrith,sydney,aus
just after some info on alternaters for my a14
wondering if there are any other cars that have an alternater that will suit an a14 of if i have to get a new one
thanks
Posted on: 2006/12/28 21:36
2 door 1200 sedan project l20b stroker
Re: alternaters
is it internally or externally regulated (the one you have now)?
Im using an internally reg one from a sunny a15 on the a15. they are pretty much the same.
Have a ford falcon internally reg one (bosch 70 amp one :) ) that im modding the mounts on to fit the datsun mounts (its in the shed and i keep forgetting to finish it).
should be good for an upgrade soon too.
1200rc modded an ea falcon one 90amps i thing for his.
Posted on: 2006/12/28 22:31
Re: alternaters
dont have one at the moment
Posted on: 2006/12/28 22:45
Re: alternaters
Quite a regular
From ADELAIDE, SA
I've got a vl commodore one on mine. Brackets are the same size, I think we had to change the pulley and maybe put an extra washer behind it to space the belt correctly. I believe it is 80 amp also, plenty of power for the crane hi 6.
Posted on: 2006/12/29 2:14
Re: alternaters
Quite a regular
From northside brisbane
has any body got photos the mods needed
Posted on: 2006/12/29 3:32
when thowing rocks at seagulls never leave a tern unstoned.
Re: alternaters
how many amps does the standard a15 alternator have?
Posted on: 2006/12/29 5:26
Re: alternaters
Standard A15 alternator is 50 amps. That's plenty for a Datsun 1200.
Pictures, diagrams and information on alternator swaps are here: club wiki - Alternator Swaps.
Posted on: 2006/12/29 5:59
Re: alternaters
is there such thing as to many amps? if so how high amps is on the safe side?what will happen if to many amps?
Posted on: 2006/12/29 6:14
Re: alternaters
Quite a regular
thank you
Posted on: 2006/12/29 6:23
Re: alternaters
Too many amps?
No -- if you put a high-amperage alternator on, it won't cause a problem. But why bother? It will weigh more and cause more drag on the engine -- both of which lower power by a bit and use more gasoline.
Yes -- if you put a big load on the alternator (High-output headlights + driving lights + big stereo amplifier) you could draw too much amps for a stock alternator. This would be bad.
Posted on: 2006/12/29 6:32
(1) 2 3 »
