Browsing this Thread:
1 Anonymous Users
can anybody tell me much about my '87 vanette |
From Adelaide, Australia
hi guys justgot a new car its a 87 vanette. it has A15 (with gx head, dont ask me why?) 4 speed colum shift and it seems to have a bigger diff centre than whats in my 1000. this also is an 8 seater. what diff centres do theese use? bluebird ones? also what ratios because i wanna be able to cruise on 100km/h without reving the hell out of it. thanx
Posted on: 2007/1/15 4:42
Re: can anybody tell me much about my '87 vanette |
Registered Users Contentmaster Usermaster
No worries, A15 is designed to rev at 4000 RPM all day long.
Posted on: 2007/1/15 5:19
From Christchurch NZ
They are hell low ratio. I put bigger wheels on my old van. It would still pull right of the clock with 15"s and non low profile tyres
Posted on: 2007/1/15 6:18
Forced Induction! Because everyone knows you don't bring a knife to a gunfight!
From Radelaide, South Australia
Its all good, mine loves to rev... spinning around too they do rev a bit at 100kmh but mine still does it with no worry's....
Posted on: 2007/1/15 9:21
Boost.. boost.. BOOST!!! Gotta love Lag... * 76 coupe, twin 40mm a12, project... * 79 ute ca18det, track/street... * 84 FJ45 landcruiser project... * 88 D21 navara 4x4, sr20de vvt daily...
what diff ratio are they. i want to be able to drive at 100km/h without eating fuel and reving out the engine all day long?
would the A15 still hold up?
Posted on: 2007/1/15 22:54
Mine has done many long trips... sits on 110 no worry's, but i agree about the fuel situation bit thursty... revs a lot.. i think there closer then 4:11 but not sure.. if anyone could shed some light on a centre swap maby....?
Posted on: 2007/1/16 0:48
i looked at the diff and it sort looks the same as a bluebird diff. are they the same type because i have a spare out of a trx
Posted on: 2007/1/16 2:14
From Canberra
4.875?? kinda rings a bell. I think thats what mr_turbo put in his 1200. Its h165
Posted on: 2007/1/16 4:58
From In front, and pulling away.Sometimes around Sydney....ish!
Yep, 4.875 is the ratio. We use this at the STEEP hillclimbs!  It came out of a Vanette.
Posted on: 2007/1/16 11:56
Lifes good when your on BOOST!
From South East QLD
Have a look on your vehicle id plate , will list a code for the Axle , you can work it all out from that ,, if its a C120 model its most like has a 4.11 H190 with the smaller axles (same size spines axles as a H165 )
Posted on: 2007/1/16 12:55
