Emissions parts?
Quite a regular
From Atlanta,Ga U.S.A.
Hi guys,
I have a 1977 datsun b210
I live in the U.S.
I am trying to find out what i can take off of the carb, headers, and intake manifold.
I wand to get rid of all the old e.g.r. stuff if that is possible.
I bought a set of 4 into 1 style headers but now im not sure if i can use them because of all the emmisions bits sticking out all over the place.
Id like to know which vacum lines i can do away with which ones ill need to plug or cap and what i can use to cap them.
I also have this weird pipe coming out of the thermostat housing that i havent seen on any other car. I think its funneling exhaust into the intake. Can it be taken off and plugged.
Any how you guys get what im asking.
Has anybody had any experience with this?
1977 b210
U.S.A. "california model" i think due to all the EGR crap.
A14 motor
Posted on: 2007/1/15 22:43
Re: Emissions parts?
From Selah, Washington
The only vacuum line I have left on my 77 is for the distibutor advance. You may run into trouble fitting the header under your intake manifold. I have a solution for that too. I will post a pic later tonite.
Mike
Posted on: 2007/1/15 23:29
Quite a regular
Thanks
Posted on: 2007/1/18 6:21
Quite a regular
So is it ok for me to just cap/remove every thing else? What about the egr valves do i need those.
Btw i dont need emissions testing where i live so thats not a factor for me.Quote:
Posted on: 2007/1/21 11:11
See our club article: Emission Controls.Quote:
Which controls can be eliminated?
Please add to the article once you do the work and tell us (in the article) more details.
Posted on: 2007/1/22 2:53
From Eureka,California
I'm looking for a good air pump,
& bracket.
Posted on: 2007/1/22 4:53
If you live in California better not remove the emission controls, unless you live in an area where there is no testing required.
Anglia man, the pumps are cheap outside of California. Try an online wrecking yard hotline, even with shipping it should be less than an California yard will charge. It's just supply and demand.
Have you checked out the price from Nissan or Krager/Grand Auto? Last I checked a remanufactured unit was only $50.
Posted on: 2007/1/22 9:16
