Browsing this Thread:
1 Anonymous Users
Thanks |
Quite a regular
Hey thanks for the fast response.
To dattodude Yea i have voltage to ecu durin startup and battery has 12v (is new not flat and stays above nine when cranking) CAS is working all mint with voltage fuel pump n lines are all mint and no fuses are blown. Coil packs are earthd on the mounts the standard wireing way. Also the 12v to middle pin of coil packs is that constant? and the other pin is earth? whats the last one for? Cheers
To demojob i dont see spark when i pull coil out and i know its getting gas and the cas is working fine. Im not using a stock ecu but it is running fine. It says in the manual it supplys a 5v charge to ignitor whice it is between 3 and 5v. Im lost haha
Posted on: 2007/2/5 0:29
Re: Thanks |
I know it sounds like the old IT comment Try turning it off then back on again. I could not find the fault at all then I undid the computer harness and stuck it back on car started straight away
Posted on: 2007/2/5 1:00
Don't You Just Love Owning a Road Registered GOKART
