brake lines....
From Bendigo, Victoria, Australia.
ran into a spot of bother while swapping my 120y struts onto my ute. i cant get the brake lines on the ute to come off...
this is the bracket im trying to get the line off at. because the 120y lines have been taken off at this point.
this is the phote of the 120y lines, where they have been taken out.
how do i get the lines on the ute out of the bracket without an angle grinder? are they push in?
anyone who has done this swap must have run into the same problem...
any help would be great
Posted on: 2007/2/24 0:54
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
Re: brake lines....
From Southern Highlands, NSW, Australia
umm theres a metal clip on the top of the bracket that has to be pulled out. Then the brake line will pull out of the bracket from the bottom. They can get pretty stiff from rust/dirt etc. so some wd-40 might help.
I hope this helps
Posted on: 2007/2/24 2:27
Re: brake lines....
ok ill see what i can do.
i drowned it in penetrene before so it should come out now.
Posted on: 2007/2/24 3:04
Bob Dylan
Re: brake lines....
yeh i slid the little buggers off. thanks for that.
Posted on: 2007/2/24 6:13
Bob Dylan
