What injectors can b ran on ca18det?
From Newcastle
i lookin 4 sum info on what injectors can b ran on a ca18det or if sum1 has sum bigger ones 4 sale?
Posted on: 2007/3/12 11:04
Re: What injectors can b ran on ca18det?
From Far, far away
Someone correct me if I'm wrong, but I'm sure I've seen R32 GTR injectors used. Not sure of the volume, but definitely bigger.
Posted on: 2007/3/12 11:52
Quite a regular
From orange nsw
Yeah its the rb26 injectors. Good upgrade, im looking into doing this if i can find sum at the right price. Not sure of the size of them though ?
Posted on: 2007/3/12 13:00
From adelaide
from memory i think they are 440s, someone correct me if im wrong!
Posted on: 2007/3/12 14:03
1200 restoration project moving slower than it actually is
From Canberra
I think that 13B injectors can be used as well - correct me if im wrong tho....
Posted on: 2007/3/12 14:30
Candy Apple Red CA18DET Ute
From Melbourne Vic
there's a lot of correct me if i'm wrongs going on
R32 GTR 440 or 444 depending on who you speak to.
13b turbo 550cc
12a turbo 880cc
all 'bolt in'
any top feed injector will work, the GTR ones should set you back around $200 for the set of four
Posted on: 2007/3/12 14:53
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From adelaide
well cant say i got the best memory Another option might be supra 7mgte 430cc injectors, there top feed also, low impedance. Pritty common, glad lags cleared it all up!
Posted on: 2007/3/12 15:27
From Far, far away
Yeah, thanks Lags. Can you help us out with this Q boys, whats the diff with cc's, bigger isn't always better right?
Posted on: 2007/3/12 17:52
From adelaide
Well from my understanding the bigger the injector the poorer it will run down low/idle but with the extra flow you can make a ton of power. But in saying that it would be a bit overkill running 550s on an na a12. Manufactures usually only leave 10-20% extra flow in the stock fuel system this way maintaining best idle, smoothness, economy etc.
Posted on: 2007/3/13 8:15
From Far, far away
Cheers bro, that makes perfect sense. The RB26 injectors should be the way to go for the CA then.
Posted on: 2007/3/13 8:21
