WTD- Stanza/sunny lower control arms
From Gold Coast
Hey guys im chasing the parts needed to install 200b front struts and calipers on a 1200 ute.. Lower control arms and whatever else is needed..
Cheers Wardy
Posted on: 2007/3/15 6:02
Re: WTD- Stanza/sunny lower control arms
From Adelaide, Australia
You'll need Stanza/sunny lower arms, steering arms, ball joints and outer tie rod ends, and late model 120y radius rods.
Or you can use stanza/sunny radius rods, but they could do with some extra thread for adjustment to get good geometry.
Posted on: 2007/3/15 9:44
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Geelong, Vic
you could even use early model 120y radious rods, just need to make the groove in it a bit bigger to clear the bigger balljoint bolts
Posted on: 2007/3/15 9:49
From Gold Coast
Thanks for the info guys.. or would i be better off going with 120y struts andv do the silvia conversion?? i want the ute pretty low over TRX rims thats all!!
What do yas think will be the better option?
I have both sets of struts in the shed
Wardy
Posted on: 2007/3/15 12:14
