stud removal
From Sydney, Australia
how can i get a snapped off stud out of the head? there is about 8mm still out - any suggestions? if i were to heat it up, would it damage
the head, or gasket?
help
linc.
Posted on: 2001/3/20 10:45
Re: stud removal
From Good Old Knockfull, Tennessee, USA
Is it a 6mm stud or is it larger? I have filed flat sides on the stub stucking out and used a wrench to turn broken studs out. If it is stuck real bad, you may have to apply heat. If you
heat it, use a hot flame and heat only the stud stub sticking out but don't melt it. I have had to use an aceytelene torch before on exhaust studs and it didn't hurt the head or gasket.
If you file the sides flat to fit on a wrench, don't turn it so hard that it rounds the flats off, you may need them to turn the stud out after it is heated.
Mareo
Posted on: 2001/3/20 11:50
Re: stud removal
Linc a few ideas.
- There are actually tools called easy outs or something similar you buy if all else fails and they are good if there is nothing sticking out. They have a reverse thread so you drill a
hole in the stud then screw them in and keep going. They have taper on them so they bite in.
- Heat is good you should only need it on the stud. Try getting it red hot a couple of times and dousing it in cold water the snap change in temp can help.
- If its not to seized put plently of WD40 or CRC on it and wind on 2 nuts then tighten them against each other and then try undoing the inner one.
These ideas are probably in reverse order of how tightly the stud is seized and I would attempt it in that reverse order as far as ease of execution. Penetrating oil (WD40) is good in
all situations. It may smoke up with the hot stud but I have never had it catch on fire.
Ipresume the head is out of the car and i don't have to remind you about the open flame in teh engine bay etc.
Posted on: 2001/3/21 6:17
Re: stud removal
From Sydney
No problem. We allways run into broken studs at work. If theres still 8mm hanging out then sit a nut over the top and mig weld inside the nut onto the stud. Easy. If that doesnt work and
the nut breaks off and u now have nothing to weld onto, get the drill out with a smallish drill bit and use some easyouts. These things have saved us many hours of work as there pretty easy
to use. Hence the name i would asssume. Another way if all else fails is to completly drill the stud out and re-tap the thread with a slitly larger size. I dont recomend doing this tho as u
should get it out correctly. Hope this helps!
Scott
Davo
Posted on: 2001/3/22 4:56
Re: stud removal
EZE OUTS - Pfff! i bought a pack of 5, and have broken 4. i dont like them much! do u have to heat
the stud with ezeouts?
i soaked em in wd 40 for hours, i tapped em, tried turning them the other way - etc etc
ill try the knurled wheel thingy i think -
thanks linc.
Posted on: 2001/3/22 6:03
Re: stud removal
Remember that eze-outs aint eze-outs.
I've got an old set that are truely ancient, used dozens of times, I think it's all in the
quality.
Heat treatment helps. getting the stods out of a turbo exhaust manifold is a truely
testing job.
Posted on: 2001/3/25 3:10
Re: stud removal
yep they were eze-out brand - the real ones - they snapped nicely too - my favourite one was where the rest of the eze out got stuck in the bolt i was trying to remove,
making it imposible to drill out...
they are fun.
linc
Posted on: 2001/3/25 8:50
