Unleaded petrol
From Batemans Bay
Hi guys,
Just wanting to know what steps need to be taken to run an A14 on unleaded petrol. And can you use 98 octane after that?
Thanks
Posted on: 2007/4/18 8:23
Re: Unleaded petrol
From Adelaide, SA
From memory, you open the fuel flap, undo the lid thing and put the petrol in...
Kidding - it should be fine on unleaded from word go.
Have a browse of THIS
Posted on: 2007/4/18 8:30
Re: Unleaded petrol
From Brisbane Australia
if this clears anything up, I have had two engines rebuilt by and old customer of mine.
I asked him what I had to do to run my A12 and A14 on unleaded, he said and I qoute unleaded still has lead in the fuel although at a lesser percentage than the old fuel he also said that alloy heads have steel inserts where the valve contacts now I cannot remember if he said hardended or not but I cant see them being mild steel.
My advise is to run a tank of Premium and see how it goes then run a tank on regular unleaded with maybe and additive and then try a tank of normal unleaded, see how it goes.
I had my A12 (freshly rebiult) running on normal unleaded with no hassles at all.
Also bear in mind the carby was fully rebuilt and all the ignition parts were new also.
cheers ade
Posted on: 2007/4/18 9:24
Re: Unleaded petrol
the only problem youll have is an increase in fuel consumption so just tune according to the fuel
Posted on: 2007/4/18 9:26
Re: Unleaded petrol
From Far, far away
My old A12 ran sweet on PULP. The only issue I've heard of is you may need a new catalytic converter, as PULP has several more chemical compounds then the old super. Some of these are even more harmful than lead.
I'm no scientist though, so don't hold me to it.
Posted on: 2007/4/18 9:43
Re: Unleaded petrol
Quite a regular
From south west sydney
hi there i am runing unled with a catalic con for 4 years with no problem Head was reco to suit unleded in my dato4x4 ute cheers josko
Posted on: 2007/4/18 12:08
Riding High!
Re: Unleaded petrol
From Newscastle, Australia
just stick unleaded straight in....92 octane is ok with factory ign timing. If you want performance you would need to up the comp and run advanced timing.
Posted on: 2007/4/18 13:25
Dont die wondering.....
Re: Unleaded petrol
From Far, far away
Not changing the cat won't affect your cars running. It's an issue for the EPA.
It's a tough one to pick up, but if John Q Law wanted to run a fine tooth comb over your beast and you got caught with the wrong cat, it'll be a nice fine.
Posted on: 2007/4/18 15:11
Re: Unleaded petrol
Techniacally the government has made a lot of pre 86 cars illeagle to drive on the road.
One of the main reasons is that they belive lead in the air is bad ( they got that right)
so they came up with unleaded fuel. now most post 86 cars are set up for unleaded with all the pollution gear cats etc but there was never anything that I can remember stating that we had to upgrade the polution gear in the pre 86 cars.
most of you who are running with out a cat are pumping benzine into the air this is more harmfull than lead in the air far worse for the environment.
one thing I would recomened is fitting a cat hi flo of corse any cat should fit in somewhere along the line. then do what people do with gas conversions and fit the upper valve stuff. this works the same as squeezing the little bottles into the fuel but its easier as you dont have to measure each time you fill up.
also get a tune to suit your regular fuel octaine if you run premium then tune it to 95 - 98 octaine if you run std unleaded tune it to about 92 octain fuel. your mechanic willl tune it (if he is any good)
my 2c
Posted on: 2007/4/19 3:17
Don't You Just Love Owning a Road Registered GOKART
Re: Unleaded petrol
From Far, far away
Thanks for clearing up the chemical and cat issue man. I'm all sorted now.
None of my running cars are pre '86 so I'm sweet.
Posted on: 2007/4/19 4:19
