Hydraulic clutch conversion
From Gold Coast
Just wondering what is the easiest and cheapest clutch m/s to use for the CA18 conversion? Is it just a drill hole and bolt in job? or is it more?
Any help will be great guys cheers
Wardy
Posted on: 2007/5/1 2:36
Re: Hydraulic clutch conversion
From Adelaide
Try Maddat they have an adapter plate that you bolt to the fire wall, and your booster and clutch master bolt to it.
I fitted one to my ute looks very neat and helps stop fire wall flex.
Posted on: 2007/5/1 2:55
From sydney, northen beaches!
hey i have got a hydraulic clutch in my A15 1200 and just wondering wat the advantages of runnig this type of clutch is!!!
Posted on: 2007/5/1 16:48
1200 Ute, A15 mildly worked,
about to be sprayed!mmmmm
AVGAS makes me FLY................
From Canberra
what gearbox do you have?
A hydraulic clutch feels better than a cable one (better than a sticky unlubricated one anyway), and you shouldnt have to worry about snapping clutch cables. It also makes life easier if/when you do a conversion.
Although i havnt used one or seen one used, the maddat setup looks real nice!
Posted on: 2007/5/1 16:58
got 5 speed with first where 2nd would be!!
Posted on: 2007/5/1 17:29
From Melbourne, Victoria
Posted on: 2007/5/1 17:56
From Gold Coast
Thanks 4NIK8, i actually have one of theses lyin around in the shed somewhere.. i was gunnu use it but thought i would ask what ppl have used.. Is there any modification needed to the rod or anythin??
Posted on: 2007/5/2 0:25
From Adelaide
If you are going to do a CA conversion at any stage, that type of master doesnt clear the intake manifold. It needs to be a short low one.
Posted on: 2007/5/2 0:34
where exactly
on the firewall?????
And where exactly does it bolt up to pedal.
Exact measurnments will be good
im doing same thing.
also guys
do use all use a flexible hose as its only bout 30mm-60mm from master to the pipe from slave???
Posted on: 2007/5/2 0:56
yeah need to cut the rod down, angle grinder is your friend :)
Posted on: 2007/5/2 3:04
