Water temp sender ohm's
From Cape Town ZA
I'm wondering if anyone knows what the ohm readings for a A12/4/5 water temp sender is at various temperatures. The Dicktator management I'm using can make use of a water temp. The is a setting where you can actually choose to manually enter the ohm readings for different temps.
It starts reading at -20 and goes up in 20 degrees Celsius increments all the way to 120. Thus -20, 0 , 20, 40, 60, 80, 100, 120. Short of addign another housing to the head and or splicing a boss into one of the water pipes, I could just as well progam the ohm reading of the sender in there.
BTW, I modified the Toy water outlet, to accept the A14 water temp sender. It's actually quite easy, you simply drill the hole right on the inside slightly bigger as the A14 sender is slightly thicker, and the threads above that is exactly the same. So you can still use the stock temp guage on the dash.
Posted on: 2007/5/4 13:00
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
Re: Water temp sender ohm's
From Sydney
Put it in a pot of water on the stove with a thermomiter and hook up multimeter.
Even u can do that
Posted on: 2007/5/4 13:49
From Cape Town ZA
I will try that, didn't even think of doing that, will post in the wiki then, then nobody has to do it again...
Posted on: 2007/5/6 22:07
1200 GX Sedan
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
