need help datsun 720 diff questions
hi there i have a 1984 nissan 720 king cab 4x2
stock motor just been rebuilt twin webers, cam ect. i was after lsd and and high diff ratios i asked around but someone said that i cant get lsd for that diff,
so first question is what diff is in a nissan/datsun 720 4x2?
what are will be the stock ratios?
and so can i get lsd put in and change the ratios or do i need to change the diff, if so what would be the easyest diff to put in with out cutting the axel down ect. thanks simon
Posted on: 2007/6/9 13:01
Re: need help datsun 720 diff questions
From Coondle, WA Australia
Just trying to remember what Dads had. he had a 4x4 diesel, and that had faily tall ratios. 4.11 or something similar I think, and i think ours had LSD, not that it worked much.
But, since yours is 4x 2 im guessing that its a smaller diff housing and a lower ratio (something like 3.9), bieng petrol, and 2wd i dont actually much to offer
Posted on: 2007/6/9 20:17
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Canberra
it'll most likely be h190 4.11 ratio. Try rally forums like bmsc.com.au
Posted on: 2007/6/10 8:35
I had both desil and king cab the king cab had a c200 lsd single cab desil had h190 single wheeler and both 4wd 's
Posted on: 2007/7/29 15:55
go hard , go quick , see yaaaa
