L22 engine
I was told that you can take a l20b engine and bore it out .080 over and use the crank and pistons out of a Z22 to make a L22, but that is all i know.
Posted on: 2007/6/14 3:30
Re: L22 engine
From Geelong, Vic
or you could just put the l20b head on the z22 and make an L22
better off using an L18 head though
you can make an L24 using a Z24 crank
more info on L and Z series here
Posted on: 2007/6/14 3:32
Re: L22 engine
From sydney australia
Ozdat has Reams of info on this. When i get tired of this L18 in the sunny coupe, I'm going to build a 2.4 litre L20b for it. I already have the Z24, & getting an l20B would probably take 1 phone call to Stewart Wilkins, who has lots of them sitting round, getting in the way.I'm just going to bore it out to take z24 pistons, & i already have a l18 SSS head sitting round doing nothing.Should make for an interesting Khana cross car.
Posted on: 2007/6/14 3:56
Re: L22 engine
From Geelong, Vic
ooo the big block L series....id do that if i even came across a Z24
but im not really that keen, although a supercharged L24b mmm
Posted on: 2007/6/14 4:05
Re: L22 engine
From Sydney Australia
mmmm
otherwise known as a grunter. sounds like this and go pretty well too.
A few weeks ago at a rallysprint a bloke in a 1600 with one beat a pretty well sorted evo.
cheers
Posted on: 2007/6/14 5:21
