A15 running standard points dizzy, standard Hitatchi carb. In a 1000 with a 1000 coupe engine loom.
Well i thought i had it all sorted! But no, no i didnt! It wouldnt start because the plugs were caboned up. Clean the plugs and hey presto she lives. But at around 4500rpm it would slutter and fart and die in the ass. Under 4500 and feathering the throttle it would be smoother but still lurchy. Adjusted timing to no avail. Seemed sluggish under 4500 to what it was before too
So then i cleaned the WHOLE fuel system out. Blew out the lines, stripped the carb, new filter etc.
It was a bit better. But still ####! So i swapped the main jets for a bigger set. It kind of cleared, then went beautifully! So i thought i would put the elecy dizzy back in. Didnt run very well at all with that! very roughg revving and was just ####... ok back with the points dizzy, in the exact same spot... runs like #### again! So i went and got another carby(Cheers Richard!) and stripped/cleaned it and put it on this morning.
Cleaned the carboned up plugs(for about the 5th time) and she fired up. Ran like ####. It seemed like it was running out of fuel after you give it about 5 good revvs, but the float bowl never went under 1/2.
Then it started doing its trick of blowing all the fuel out the carb, like a big backfire(no flames or BANG). Its just like a mass of compressed air pushed back out the caby. blowing fuel out the top and out the top gasket. It does it like every rev of the engine too... like the valve overlap is too big and its pushing the exhaust out the inlet???
Any ideas this time
