How do I make some spacers for my ute?
From South america
Dear friends,
I would like to place in my 93 ute some 15 inch rims, but I realize that some rims will rub parts in the chassis, and also it may not be nicely aligned horizontally, means wheels too much inside. So my questions is how to make some spacers and or adaptor, maybe also changing 4x108 separation to 4x100 most common separation.
thanks a lot.
Posted on: 2007/7/25 17:53
Re: How do I make some spacers for my ute?
From perth airport
best to buy spaces but they are not aloud in most states
Posted on: 2007/7/25 19:25
Of course, there is the alternative, ... you could use the correct offset wheels in the first place & not need to deal with potentially illegal spacers.
Sounds like a plan.
Posted on: 2007/7/25 21:50
Love your Datsun.
Treat it well.
From perth airport
hey hey thats too ezy lol
Posted on: 2007/7/25 21:57
From South america
Yes indeed, I am aware of that, but here in south america that is not a problem. if somebody had some pics and or dimension it would be lot easier for me. I think that spacers are not easy to build and make it in CNC may be too expensive.
Posted on: 2007/7/26 15:18
From Sydney, Australia
mate.. you are going to have to understand that you may not be able to achieve this. You are talking a lot of effort to achieve a cosmetic result.
You need 4 x 114.3 bolt pattern wheels.
You could modify the axle bolt pattern to 5 x 114.3 using S13,S14,S15 parts.
It should not cost 'the earth' to import the appropriate wheels from the USA to satisfy your needs...unless you are in Cuba
Posted on: 2007/7/26 16:35
From South america
Yep, Its not a bad idea, but like you said the cost to do that it may not worth it. You just put me back on my senses. Looks its not the most important to me, and I guess is not for everyone here, otherwise we will not had fallen in love with old dattos, correct me if I`m wrong.
I will just look for the best looking wheel that fits.
thanks a lot
Posted on: 2007/7/26 16:48
From South Africa
Other Than Spacers, Remember 15'tyres will require low profile tyres,
I have proper set mags fitted to my Ute, No spacers was needed, however i still had to trim the front end of the wheelarch in front. And I have 195, 45, 15 Yokohama tyres on.
Spend a lil more, and put on well specd set of mags and tyre
Here's mine Open in new window
Posted on: 2007/7/27 5:01
Life's a bitch, so f...k it.
From Victoria
Hi I made hub adapters for my race car, it wasn't that hard. You get some alluminium round and a lathe and machine them up.
Posted on: 2007/7/27 8:07
