wat's the best hevay duty cultch for a ca18t
From townsville qld
hi all, wet out to the drags last night and after 3 runs my cluth started to slip real bad let it cool down and i was able to drive the old girl home but i'm preety sure it's dead so just wanted to know wat hevay duty clutch everone is running
cheers matty
Posted on: 2007/8/4 18:20
Re: wat's the best hevay duty cultch for a ca18t
i have a excedy soild centre 5 puck brass button in mine.
it loves the drags, never slips.
make sure you get your fly wheel machined.
Posted on: 2007/8/4 18:50
From townsville qld
ok thanks oan878
Posted on: 2007/8/4 18:58
I'm very happy with my x-treme cushion button clutch. they cost about $400-450 new
Posted on: 2007/8/4 22:12
From Sunnybank, Brisbane
what is a cushion button???? brass button cluches can destroy gearboxes on a daily driver. does a cushion button have a balance point?? ive never heard of em. i"ll be doin my clutch soon as well, have heard from datto guys round the 800 mark for a decent one
Posted on: 2007/8/4 22:49
taken from the x-treme website.
" Has a rigid centre with cushioning segments between multiple ceramic buttons bonded to steel backing. Ceramic linings offer greater torque capacity, much higher coefficient of friction as well as higher heat stability and dissipation.
Offers a great driveability with the advantages of using a sintered lining, relatively smooth and positive engagement, suited for street and sprint use. "
Because the friction plate is cushioned it makes them much more gentle to engage than a solid brass button plate as there is some give in the thickness of the plate. Once all the pressure is down they still grab and hold very well though.
Posted on: 2007/8/5 0:11
you'll find that most (nearly all) standard clutches are "cushioned" in between the two facing of the friction material they pretty much have "kinked pieces of steel which as the clutch engages helps to smooth out the engagement.
Posted on: 2007/8/5 0:17
yeah exactly, the cushioned button clutches take advantage of the cushioning of a standard clutch but with the increased friction coefficient of the ceramic inserts.
Posted on: 2007/8/5 0:20
From townsville qld
so would that be better 4 for street but still be strong 4 the drags ive heard that brass button's kill gearbox's after awile
Posted on: 2007/8/5 0:24
From Canberra
I've heard that button clutches also chew out standard flywheels... I have a exedy 'sports tuff' 4 puck button clutch, it slips real bad... might not be the clutch's fault, but I read of one instance where one was tested and it had less clamping pressure than the standard clutch.
OS Giken twinplate is the way to go
Posted on: 2007/8/5 0:30
