Big brake struts
From Adelaide
Im selling a set of struts and brakes on ebay, if anyone is keen.
They have only had about six months of use, and work fantastic.
Posted on: 2007/8/5 4:01
Re: Big brake struts
From Adelaide
Posted on: 2007/8/5 4:02
From Geelong, Vic
clickable
just a question about this brake setup, you have to tap a thread into the r31 struts to use those brackets dont you?
Posted on: 2007/8/5 4:07
From Adelaide
Thanks for the link.
Yes you have to drill and tap the struts, also you need to grind some off the area around the mounting holes and grind a bit off the callipers.
Posted on: 2007/8/5 4:13
From Geelong, Vic
was wondering how to they get the caliper in close enough to use the 280mm discs
on the 200b struts i couldnt get it in much further than about a 292mm disc (machined down 296mm) wthout grinding down the caliper
Posted on: 2007/8/5 4:19
From Gold Coast Australia
Hey SSSUTE I was going to ask you on ebay but since I have found out they are yours I will ask you here, What is needed for them to fit on a Sunny? Will the standard lower control arms and radius rods work?
Will these fit under 15" wheels?
And also what would frieght be to 4223 in Queensland?
Cheers Mitchell
Posted on: 2007/8/5 5:32
SR20DET Sunny for sale, click me for details
From Adelaide
Pigdog, the 200b bolt positionings might be slightly different to the R31 struts. Even with the r31 struts you have to grind a bit off the bolt flange.
Posted on: 2007/8/5 13:49
From Adelaide
BAD310, they should fit straight on to your Sunny, as im using Sunny lower control arms.
They will fit under 15inch wheels, but they may need to be a fwd offset depending how wide they are.
Cheers Scott
Posted on: 2007/8/5 13:57
From Adelaide
Bad 310 freight to you would be $70
Posted on: 2007/8/5 13:58
I was going to use the SR20 turbo rotor and caliper setup on the front, so having the centres moved on the front wheels isn't a big deal if need be.
Does the auction include the spanners for the coilover adjustment?
Now I just need to win them
Posted on: 2007/8/5 15:35
