battery cable from rear to engine bay......questions...
installed battery box-switch-negative in the tray of my 1200 ute.
what size possitive cable is recomended???
Where do use recomend i run the new cable???
in my p plating days i had 6 subs in boot and had 2 run a thick ass positive cable its see through red its at all good car stereo places
is this good enough
also have same tickness but in a garder isulation like a plasic not like the red rubber like cable
any recomendations in (mm)..etc..etc
Posted on: 2007/8/12 23:23
Re: battery cable from rear to engine bay......questions...
Use both a positive and a negative cable all the way up to the engine block and starter. Don't rely on a ground/earth through the body...
Posted on: 2007/8/13 2:01
From Bris-Vegas
Yep, you need the -ve cable to earth on the engine... Not the chassis.
I ran mine under the drivers seat which allowed me to install a cut-out switch for security puposes.
Posted on: 2007/8/13 7:20
CA18DET '74 1200 ute project
From Tracy ,Ca
what motor are you running and type of curent draw do have from your starter. i run a 4 gauge wire from my battery for my a-series. but if you are running abig stereo system i would run 1 or 0 gauge wire
Posted on: 2007/8/13 7:23
Quite a regular
Don't know gauge sorry but I just earthed the battery in the boot to the chassis and put an extra earth strap on the block.
I ran the cable tacked against the floor under the car and bought the cable inside by cutting a hole at the rear of the back seat and grommeted the hole.
Had it like that for 4+ years with a 351 on the other end and never had a problem.
Posted on: 2007/8/13 8:20
From Brisbane, Australia
I had my earth to the chassis and an earth strap to the engine. nothing wrong with that. no need to run the negative all the way back to the engine. If you do it that way, it still needs to earth on the chassis somewhere too.
The positive cable should be sheilded in conduit and clamped to the body to prevent it moving and wearing through.
Posted on: 2007/8/13 9:14
so earth to chassis at rear.
earth block to chassis at front along with sarter negative.
where should i run the bulk of the power cable
to starter motor
or
alternator
and for all the rest of original 1200 loom should i power up where old possitive terminal was and earth old negative terminal to chassis aswell
there aint to many wires
i ran all blinkers etc
still working out
starter motor wires
alternator wires
are they on LEFT or RIGHT side of eng bay
Posted on: 2007/8/13 14:32
