brakelines/original wirring.
where does the front brake line distributor box bolt to fire wall????
i found all lights blinkers in wirring
any diagrams or pics to see what all extra wires are for
such as
horn washer starter alternator
there aint many left but want to no what there for
even if some 1 can explain
the 1st wires taht come out of loom is 3 green wires(short) then more wires after that
Posted on: 2007/8/16 15:24
Re: brakelines/original wirring.
From SE Melbourne
Hope this helps.
Posted on: 2007/8/16 17:54
Mildman, Datsunless
front brakes done...
but thanks for photo it is exactly how i did it.
where can i get more pics close up of wirring???
how do i post pics like you did???
Posted on: 2007/8/16 19:43
From SE Melbourne
To post an image click on the IMG button when posting and to post the image just copy the hyperlink of the image into the IMG text box.
Outcome should look like this.
{img]Hyperlink here[/img}
Just change the curly brackets on the end into square brackets for it to work.
The photo below is from my webpage and has the link
{img]http://mildman.datsunprojects.org/images/100_2320.jpg[/img}
Your avatar is linked like this for instance.
{img]http://datsun1200.com/images/avatar/users/8204.gif[/img}
Posted on: 2007/8/16 21:54
Mildman, Datsunless
how do u get the name address thing
Posted on: 2007/8/17 11:25
From Sunshine Coast, Queensland
here you go ....
daveman's explanation from a while ago ....
When you looking the a picture in the photo album, right click on the picture and go down to 'properties'. A little box will pop up with 2 URL's in it. You need to highlight and copy the bottom address (the one that ends in .jpg) . This is the address of the image you need when you try to insert the image in a response to a main forum thread.
boofheads version as well .........
right mouse button click on the photo on the screen, on the pop up hightlight and copy the properties bit.
go to the post thread/reply screen and the little button that has IMG just above where you type click on that, a pop up comes up and then paste the photo properties that you copied from the picture into it .... ok the next bit till you get the hang of ... preview your handy work and if you get the post looking like what you want hit submit and bob's your aunty .
hope it helps
Posted on: 2007/8/17 22:24
75 datto ute - now selling
73 datto sedan - now building
simmos NEW ute build
