datsun 1000 problem
hey all my Datsun 1000 ute has a problem when you drive it after a while it starts to splatter and what not and then just die and then ya go to turn it back on and it will keep going for about 15 seconds any ideas cheers
**EDIT**
Posted on: 2007/8/17 10:09
Re: datsun 1000 problem
From Wagga Wagga
the only thing you can do is check the fittings (check bulbs) if that does not work try rewiring and if that does not work you might have to replace them.
Posted on: 2007/8/17 10:28
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
all good found out what the problem was cheers
Posted on: 2007/8/17 12:22
From Perth WA
just for reference, check fuses/relays first. dont go jumping to conclusions and rewire the whole car burk-a-lot!
Posted on: 2007/8/17 14:33
Chris...
yeha i did and the fuse was broken the end fell off now i have another problem
Posted on: 2007/8/19 7:54
