JE piston info
hey guys I need to re-ring a datsun 1500 motor, and it has 79mm JE pistons in it. Does anyone know where to find new rings for this? I checked on the JE website and they do not show any application even close. Any help is appreciated.
Posted on: 2007/9/7 4:49
Re: JE piston info
From Christchurch NZ
Dont bother, just give them to me!
Posted on: 2007/9/7 5:13
Forced Induction!
Re: JE piston info
There's a good chance it uses the regular Nissan ring size. Give JE a phone call, they should tell you the usual way. Then you can measure the ring grooves to verify.
Posted on: 2007/9/7 6:47
Re: JE piston info
From Brisbane, Australia
shouldn't be a problem for any decent parts interpreter. all you need is the bore size and the ring widths. they can cross reference that to a part number. doesn't matter what car they're listed for as long as they fit the piston.
Posted on: 2007/9/7 8:40
Re: JE piston info
From Adelaide
Once you know all the piston info, please post it up!
Posted on: 2007/9/7 15:57
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
