Browsing this Thread:
1 Anonymous Users
turbo setup |
From adelaide
Im bitting the bullet and going gas research setup and 600hp turbo etc aiming over 200rwkw on standard bottom end so my current setup is up for sale, still in car running so can test. All in excellent condition
Haltech e6x plus loom fully tuned by adrian @ rpm performance, boost cut at 18psi tuned to 17.5psi usually ran on 1 bar
Dissy modified to suit system custom plenum, xf throttle body, 430cc injectors, custom fuel rail, burst plate
turbo manifold of steam pipe and tdo4l wrx turbo only less than 20k kms old plus 3inch dump to under car
supra cooler fits behind grill
vl turbo pump only 2months old plus surge tank plus malpassi regulator with fuel pressure gauge
intake to turbo inc 3inch pod filter
cooler piping for 1200 setup, no BOV, 2 inch piping
Has done 120rwkw on standard l20b bottom end with cam timing retarded by one tooth accidentally and only 5500rpm limiter and safe tune (did 109rwkw @ rpm performance on 8psi with correct cam timing) so now at easy 140-150rwkw more with increase to 6500+rpm limiter. Lots and lots of time, trial and error has gone into this setup, great for a bolt in mega power up.
You will need good clutch even heavy duty 280xz clutch couldnt cut it! Price: $2600 ono obviously setup owes me well over double that. Unfortunatelly pics are down but can email some on request. Located in adelaide
Posted on: 2007/10/19 10:26
1200 restoration project moving slower than it actually is
Re: turbo setup |
From adelaide
bump price negotiable
Posted on: 2007/10/24 3:23
Re: turbo setup |
From adelaide
bump
Posted on: 2007/10/28 3:27
Re: turbo setup |
From adelaide
will require series 1 or 200b engine or pistons 8.5:1 or you will have headgaskets blowing at more than 8psi from pinging.
Posted on: 2007/11/1 6:48
Re: turbo setup |
From gold coast
hey man is there any chance of shipping or anything like that cause my brother is pretty intrested he has had the work done to hold the prerssure. cheers
Posted on: 2007/11/2 9:15
Re: turbo setup |
From adelaide
Yes but and its a big but, i dont want to get ####ed over by ripping the setup off and having you bail on the deal so i guess we could work something out i could take a #### load of pics so you no exactly what your buying then maybe a deposit or something. How keen is he and does he have the $ at the moment. Were abouts are you champ? Let me no
Posted on: 2007/11/10 0:18
Re: turbo setup |
From adelaide
bump
Posted on: 2007/11/17 23:43
