1200 clutch
From canbetown nsw
wot parts do i need to convert my 1000 box to the 1200 gearbox does anyone sell a kit or is it the same plz help
Posted on: 2007/11/12 8:35
Re: 1200 clutch
Not really sure what you mean. If you've got a bigger motor like an A15, A14 in the stock 1000 I'm pretty sure people reccomend a 1200 gearbox be used. There's a little bit of work to fit it (tunnel massaging to enable sufficient space for clutch) but it relatively easy.
Thats what I've gathered, I might be wrong. Is that any help?
Posted on: 2007/11/12 8:47
Re: 1200 clutch
From canbetown nsw
sorry for the bad infoill be putting in the 1200 motor and box in my 1000 just need to know if i have to convert the clutch
Posted on: 2007/11/13 7:03
Re: 1200 clutch
From canbetown nsw
anyone
Posted on: 2007/11/15 5:35
Re: 1200 clutch
From perth airport
do you have both motors/gearbox sitting there ? i dont remember wat the set up was on my a12 was but i think it was a cable set up and the a10 is cable too so i think it should be ok but look at the two gearboxs and im shore you could figure it out
Posted on: 2007/11/15 5:50
perth airport parking
Datsun 1200 ute A14
