what do you guys think of backyard head porting on a throwaway motor?
From bathurst nsw
ive had an idea, my mate wants to enter his standard single cam engined corolla in the bathurst supersprint in december and his twin cam motor wont be ready, so we have been looking for cheap power.
the thing is we have a dremel, no tallent and are probably over eager to do all of this lol
so i had a thought, we have 2 single cam engines that will never be used again and i have a practice head we could use (its warped 50thou), do you guys recon a bit of porting would help on the standard motor?
i was thinking doing both the exhaust and inlet and then possibly the exhaust manifold. we have done the usual for more power, service (we already had all the parts so no biggy), weight reduction, removal of heater core and also emissions gear aswell. any other ideas?
as its a corolla ive got no idea what else we could do. its an ae71 with a standard 4ac engine in it if that helps.
cheers guys
p.s. please dont post that we are crazy because we already know that, lol
Posted on: 2007/11/14 23:23
My car gets me from A to B...Just faster ;)
Re: what do you guys think of backyard head porting on a throwaway motor?
From Sydney
go for your life.... theres only one way to learn.
Posted on: 2007/11/15 1:06
Go it mate. A steady hand and lots of patience, so keep the beers well away until you're done- well almost done. If it's all even there shouldn't be much drama. I know it's done quite often, just do it neat and uniform and you'll have a winner!
Posted on: 2007/11/15 1:12
From Newcastle
Go nuts i would lol. . . not like it a lambo or anythin . . . port it till theirs nothing their lol
Posted on: 2007/11/15 1:38
From Brisbane, Australia
A simple cleanup of any casting marks and a good port match should be more than enough. . .
Use the gasket as a template.
Unless you are changing the cam and induction don't go too crazy.
Check out the corolla forums, may pick up a cheap cam. . .
Posted on: 2007/11/15 2:24
Quite a regular
From Penrith, NSW
pointless with out changing the cam,but fun none the less.
Posted on: 2007/11/15 2:37
From Tamworth, NSW
Not pointless. What i think you ment is you would get better gains out of the porting job if you put a cam in itat the same time.
Posted on: 2007/11/15 7:57
Project coupe:
Just drive it
Porting a head is not pointless if done properly....
Although you can make it worse if not done right... and bigger is not always better...
Remove the the sharp edges on the short turn (the smallest radius on the bottom of the port about 10-15mm before the inlet valves)... If you are going to increase port size dont remove material from the bottom of the port (mounting face inwards)... raise the top of the port by 2-3mm's going in only about 30-50mm and blend in with the existing port...
May not sound like a lot but it will be an improvement, not a disaster... Your trying to create a venturi just before the valve, to increase air speed, not a big hole with no air speed...
Posted on: 2007/11/15 10:11
From Adelaide
Woody, Do it!
You might struggle with a Dremel, it will be quicker if you upgrade to a Die Grinder with a good spur bit tho.
Good luck.
Posted on: 2007/11/15 10:55
From bathurst nsw
my thoughts exactly sssute, well we are still probably gonna do it as well as the standard exhaust manifold just for a bit better flow.
thanks topgear ill use that advice
thanks everybody, now ive got to convince my mate to stop having second thoughts coz he recons it well do damage to the motor. my argument is that it wont and that if for some random reason that it does (right foot lol) he has a spare engine that we could put in it if his twin cam isnt ready before next year sometime.
thanks for the support lol, kurt
Posted on: 2007/11/15 11:05
