Will a ca18det have the same mounts and gearbox bolt pattern as a ca20?
From In front, and pulling away.Sometimes around Sydney....ish!
Guys, I have just bought a Sunny B310 coupe with a ca20 fitted. Will a ca18 use the same mounts for the front crossmember and have the same gearbox bolt pattern? Any help will be apreciated!
Posted on: 2007/12/22 10:30
Lifes good when your on BOOST!
Re: Will a ca18det have the same mounts and gearbox bolt pattern as a ca20?
From Sydney, Australia
yes, a CA20->ca18 transplant will be 'mostly' as easy as switching out blocks and rewiring.
I don't expect clearance at the back of the head will be an issue.
Posted on: 2007/12/22 10:38
Thanks Dattodude, thats just what I wanted to hear! The wiring is there, but not hooked up, so will save me the trouble.
Posted on: 2007/12/22 10:39
Well, change of tactic, after picking up the coupe, it is TOOOO good to butcher, so will be getting an A14 back in. Then just cruise in style!!!
Posted on: 2007/12/23 0:23
From ACT Aus
my utes got a ca20 in it which it had when i bought it and i was thinking that in a year or two i might put the ca18det in. so it pretty much just bolts in? my diff is up to it but i was wondering if the ca20 gearbox will cope with the power?
thanks
Posted on: 2007/12/23 5:33
From Far, far away
CA20 box should handle the power of a CA18DET with minor mods no worries.
Posted on: 2007/12/23 6:22
