Speedo cable
From Wagga Wagga, NSW
well i snapped my speedo cable today. so i gotta put a new one in tomorrow.
could anone briefly tell me the steps??
any help would be great!!
will the cable from a 120y a12 go into a 120y with an a15??
thanks
Posted on: 2008/1/2 11:20
Re: Speedo cable
From Perth WA
what gearbox? I would say yes either way tho.
Ok heres what to do
1) Unscrew the fitting from the gearbox.
2) Unscrew the fitting from the back of the speedo guage.
3) Thread the cable though the engine bay and firewall and remove.
4) Replace!
Posted on: 2008/1/2 11:27
Chris...
Re: Speedo cable
not sure what gearbox, just standard 4 speed i think.
so i dont need to take the dash off?? id hate that!!
thanks for the help too!!
Posted on: 2008/1/2 11:31
Re: Speedo cable
From Perth WA
Nah you should be able to reach up under the dash. Should only be finger tight. A light and laying upside down may help!
Posted on: 2008/1/2 11:36
Chris...
Re: Speedo cable
righto, ill give it a go tomorrow.
thanks
Posted on: 2008/1/2 11:37
Re: Speedo cable
i done everything you said beattie.
i hooked it all up and it isnt working..the little bit that goes into the bgearbox looks different to the other one, but it fits in good. and ive tightened it on the back of the guage as much as i can..
Posted on: 2008/1/3 0:18
Re: Speedo cable
From perth airport
to test the speedo cable you could undo it from the dash and and go for a quick drive and see if the cable is spining . if yes, sounds like your dash is US
if not spinin the cable it the wronge one
hope that helps
Posted on: 2008/1/3 0:22
perth airport parking
Datsun 1200 ute A14
Re: Speedo cable
well i took it for a drive with the cable out, it was spinning.
so does that mean i have to change my gauges?? but it was working yeterday before the cable snapped.
oh yeah and i spun the thing on theback of the speedo and the speed change. does this just mean im not conecting it right?
Posted on: 2008/1/3 0:31
Re: Speedo cable
From perth airport
maybe or its the wronge cable ?????
Posted on: 2008/1/3 1:10
Datsun 1200 ute A14
Re: Speedo cable
still spins tho, so itd have to be the right cable.
i guess im not putting it on properly..
Posted on: 2008/1/3 1:21
