Purge Line Setup Question
From Mandurah, Western Australia
Have a CA engine fitted with the required charcoal canister and a line to the rear for purge.
I have a 6mm barb on the top of the tank for purge/fumes but what stops the fuel comming up this line.
I hade a look at the CA18DET manual and in the diagram it has a fuel check valve at the tank on the purge line.
I assume this stops fuel comming up the fuel line?
If so where can you get one of these valves???
Cheers Guys and Girls
Posted on: 2008/1/17 11:14
Re: Purge Line Setup Question
From Sydney, Australia
all newish cars will have one someplace, sometimes they are built into the carbon canister..
Have a dig around at the wreckers.
Posted on: 2008/1/17 11:44
So it looks like a valve, about half size of film canister? In the purge line near the tank if it's not in the canister itself?
Posted on: 2008/1/17 11:52
I'd have to have a look. Many s13 guys have blocked their pipes, and found the valve to be blocked too. some have had tanks explode, dumping all their fuel on the road.
Posted on: 2008/1/17 12:22
