gearbox for A14 engine in a 1200
Not too shy to talk
From Hobart, Tasmania
Ive already posted this message but I didn't get a reply. Im after a gear box for my 1200 coupe because the old one has blown up. Ive got an A14 engine installed and Im
wondering what gearboxes will go in (I don't particularly want to put a 1200 gear box in because they are old). Will the 84pulsar gearbox go in? or what about a 120y
one?
Is there a 5 speed that goes in without too many mods?
Can anyone could recomend a gearbox that will go in without much modifying?
Thanks,
Andrew
Posted on: 2001/5/23 9:07
Re: gearbox for A14 engine in a 1200
From Fort Worth, Texas, USA
Andrew, the five-speed that came in the '79-'81 US 210(B-310) will fit with some crossmember mods. The 120Y five-speed will work, but if it is a "dog leg" with first gear down and
back, I would try to find the B-310 unit. You might encounter speedometer cable fitment problems. Actually, speedo cables have been the only big problem I've had with the newer boxes.
Hope it helps. Tim
Posted on: 2001/5/23 9:32
Andrew I have an A series 5 speed that will bolt straight to the engine. Gearbox mount will need to be fabricated out of the old one but it is easy if u can weld. I couldn't and
it only cost $20. The parts are still available for these gearboxes and I have a high horsepower A15 and I haven't had any problems.
Gearbox is $600 but I am open to offers.
Posted on: 2001/5/26 9:29
