TRD LSD for H165 conversion
From Perth
I am selling all my TRD stuff, so this spare LSD has to go. It is a 2 way TRD LSD currently NOT modified to fit in a H165 housing but if you look at the Pit Road site you will see this is the unit they convert (turn down bearing sleave and fit datsun bearings) it uses the same spline axels so it look like an easy conversion but i am not sure what crownwheel pinion they use. I am selling the LSD for $800 ono
I also have a complete sprinter diff centre as used im my Datsun 1200 Coupe rally car it runs TRD 5.3 gears TRD 2 Way LSD and has a modified input yoke to suite datsun tail shaft. (i used a modified sprinter housing but you could modify a H165 housing or even get a TA22 corolla housing and axels) selling the centre for $1500 ono
Posted on: 2008/2/28 7:37
Re: TRD LSD for H165 conversion
From Perth
Pic of complete centre just before fitting the 5.3 Gears.
Posted on: 2008/2/28 7:40
From Perth
bump
Posted on: 2008/3/4 9:51
From Sydney
5.3 I never even knew diffs when that high lol must be good for towing trains hahaha
Posted on: 2008/3/4 10:53
