Keeping it Original
From Nyngan, nsw Australia
Done the full 4 wheel disc brakes (skyline R31)....
now would or should i change to a booster or is it ok to leave original setup (ute)??,
working progress
Posted on: 2008/3/6 19:54
Re: Keeping it Original
From Far, far away
I assume you're running a CA? You can get by without one if you don't mind pushing the pedal to the floor, won't effect the braking performance. Adding a booster isn't difficult though.
Our wagon has an LA Lancer booster that bolts straight up to the firewall. All that is needed is a little massaging of the inner guard and drill the hole in the brake pedal a little bigger. Others have used 180B boosters (needs a bracket to attach to the firewall) or gone remote (VH44). None of these boosters mentioned is particularly expensive unless you buy a recoed VH44
Posted on: 2008/3/6 21:28
I'm told that the GA & GB Galant booster is also a bolt on deal also. Probably the same part.
Posted on: 2008/3/9 4:11
Love your Datsun.
Treat it well.
From Canberra
A reco'd anything really. I paid $180 to get my 120y booster done.
Posted on: 2008/3/9 7:59
yeah well im in two mines at the moment,
CA yes but i like SR but hearing around that SR mite be a to bigger deal bit mucking around,
so CA will be a good starter for me, well i didnt no about the lancer booster bolting straight up,
sound good theres a few wreck about mite grab one,
cheeers
Posted on: 2008/3/9 10:36
