Radiators? I need a small/slim one.
I'm trying to find a small radiator, one that is slimmer than the original 1200/1000 ones. Does anyone know of any small car radiators that are ideal for what I'm looking for??
Chris
Posted on: 2008/3/31 3:40
Re: Radiators? I need a small/slim one.
From Florida, USA
I used a Rabbit/ Scirocco rad in my 1200 race car. Had to use a piece of tube to transfer the water from left to right under the fan. Rabbit/ Scirocco rad is double pass all aluminum with plastic side tanks. Worked great. Needed to make custom mounting that consisted of a piece of aluminum flat stock across the bottom of the rad mounting to the front inner frame and some upper brackets to hold the top to the rad support.
Posted on: 2008/3/31 4:04
