Browsing this Thread:
1 Anonymous Users
A Series Datsun Gearbox Speedo Drive |
Quite a regular
From Redland Bay Brisbane QLD AUSTRALIA
Is it common for the speedo drive in the G/box to Brake?
My speedo was making some noises, the needle bounced a few times then went to "0" & has stayed there. Upon investigation there was a slight kink in the cable, so I bought a new one. and it works fine on the speedo powered by a electric drill, but it won't move when connected to G/Box. How do you fix this?
Posted on: 2008/4/19 7:54
1960 A15 Nissan Powered Morris Minor 2 Door & 1950 Sidevalve 918cc Powered Morris Minor Tourer
Re: A Series Datsun Gearbox Speedo Drive |
From Toowoomba, Qld
I've broken one previously. It's only a (10mm)? bolt to pull the speedo drive from gearbag to check it out, and the gears only made of plastic. Probubly pick one up from the wreckers for nothing.
Posted on: 2008/4/19 8:03
