1200 coupe front struts - help required
From Perth WA Australia
I have upgraded the front springs (king springs) and noticed the left front strut seal has gone and needs to be replaced. Does anyone know if parts are still available and do the tops just screw off, or is a special tool required to remove them as per the workshop manual. I am going to incorporate coil overs to get the correct ride height as the back is currently sitting lower than the front (2 inch lowering blocks). I am not keen to upgrade the front suspension any more, at this stage - due to cost. Any help or advice will be appreciated.
Thanks Tom.
Posted on: 2008/5/9 4:53
Re: 1200 coupe front struts - help required
Thanks for the PM's
Tom
Posted on: 2008/5/9 8:24
