Rust Repairs? What works what doesn't
From Wallan, Vic, Aus
Hey there, I'm fixing some rust holes in my datto and have cut some neat square holes to remove it, then applied rust converter. I was going to hire a welder and weld up the holes with some metal. But before I do, what things have other people done other that welding and stuffing around with cutting metal to size and hiring a welder, is there some other way to do it so it lasts a long time? I did bog last time but it only lasted 2 years. Cheers
Posted on: 2008/6/13 12:36
Re: Rust Repairs? What works what doesn't
From SE Melbourne
I've heard good things about POR15 and KBS coatings - am planning to use one of them on the boy's rusty 'rana - so I'd be able to tell you in around 3 months.....
Posted on: 2008/6/13 12:57
Mildman, Datsunless
From sydney
Fibreglass cloth applied with POR15 from the inside, when its all set skim of bog over the top, its not the proper way to do it but if you have cut the rust right out then it wont be coming back through the POR15.
Posted on: 2008/6/13 14:28
From Croydon Victoria Australia
As far as i'm concerned you can't go past fresh metal welded in and then plenty of rustproofing - a coat of primer or rust converter and a coat of fish oil; reapplied every year or so.
Posted on: 2008/6/13 15:36
Hmm okay. What is this POR15, never heard of it, is it like bog?
Posted on: 2008/6/13 15:44
From Townsville, Qld
Iit's a painting system that has a really immaculate durable finnish one it's dried. You do have to protected it from uv rays but if it's in the engine bay that's not really a concern.
POR15
Posted on: 2008/6/13 20:51
