L series air con
was wondering if any gurus out there know if the L series air con compressor is the same size and mounting as the A series air con unit?
Pipes etc can be worked out but compressor unit is my major concern. guess any thing can be fitted with modded brackets but would be easier if had one that fits.
already have the pully on the crabk shaft thankfully
Posted on: 2008/6/25 12:19
Re: L series air con
From Geelong, Vic
you would want to buy an L series aircon setup after ive thrown out the complete 180b setup i had wouldnt you
Posted on: 2008/6/25 13:23
From Adelaide, Australia
Just find a sunny or 120y out there with the compressor and bracket, I see them all the time at the wreckers here, I've been tempted many times to grab the whole lot and try retrofit it into a 1200, Im always buying something else though and just can't part with the cash.
Posted on: 2008/6/25 13:47
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
if id know you had one piggy i wouldnt have tried to buy one!
I have never seen an aircon compressor at the wreckers on a sunny a series or 120y. if i had i probably would have grabed it!
Posted on: 2008/6/26 6:55
