how strong is the 1200/120y auto trans?
From Adelaide, Australia
hey guys just wondering how much power the auto trans on 120y's and 1200's can take? just wondering if its better behind my E15et
Posted on: 2008/7/7 8:50
Re: how strong is the 1200/120y auto trans?
Most 1200's & all 120Y's used the Jatco 3N71B trans [early 1200's & 1000's used the 3N71A]
This sambe basic 3N71B trans was also used in the larger L series powered cars along with a number of other Jap car makes & models.
The overdrive version, the 4N71B was also used behind the six cylinder Skyline models & the Comodores that used the Nissan engine, as well as being used in smaller 4 cylinder 2 litre cars like the Pintara.
The clutch packs & other internal pieces are tailored for the engine that drives it, so you could put a 1200 trans behind a six cylinder L series, after all, they were both 3N71B's but the six would cause the 1200 trans grief & the beefier trans behind a stock 1200 would suck up all the power just to drive it.
So here's your answer. The 3N71B trans that is used behind a 1200 is tailored for the 1200's output & pumping big grunt through it will apperciably shorten it's service life, but it can be rebuilt using components from the more powerful models to custom tailor a trans to your needs.
Alternately you could use a 3N71B from a bigger model that put out more power anyway.
Have a chat to a transmission expert to get all the right answers
Posted on: 2008/7/7 9:26
Love your Datsun.
Treat it well.
