13" superlite fitment & clearance
From Palmerston North , NZ
just want to no if 13x7 superlite will fit inside 1200 coupe guards , i want to run 185/50/13 or 175 on a 6" rim , any info will be a big help
Posted on: 2008/7/9 0:29
Re: 13" superlite fitment & clearance
From The garage, NZ
depends how low you want to go...
I had no problem fitting mine on the wagon or the ute with a 175/50 (13x7's i mean) and the ute is really low and the wagon has quite low.
185/50 isnt a bulbus tyre although it isnt tiny either, i do not forsee any drama with them in the gaurds, or flush with the gaurds.
Most i did was bend the inner lip up on the front and rear so it didnt chop into tyre if it did rub.
They should fit beautifully...
Posted on: 2008/7/9 4:16
Cheater_5, do you have stiff springs? I would think you'd need them to prevent the tires coming up to hit the edge of the guards.
Posted on: 2008/7/9 4:54
From Mandurah, Western Australia
The 175 on a 6 inch rim will fit. If you are running standard struts a 185 on a 7 inch rim may fit without flaring guards.
I have Stanza struts with a 185 on a 6 inch wide 14 inch superlite and it just sits inside the guard.
Posted on: 2008/7/9 5:02
From ACT Aus
my ute has 13x6 inch rims with 205/60 tyres on the back and 185/60 tyres on the front. it has stanza struts in the front with adjustable strut tops and 2 deg neg camber and a torana diff in the back.
Posted on: 2008/7/9 8:22
From The garage, NZ
well if you lowered it enough for the wheel hitting issue to be a problem then you'd want stiff springs anyhow....
But yes i have 250lb/in fronts
Posted on: 2008/7/9 9:19
165 65 13 fit on there too. legally as well.
Posted on: 2008/7/9 23:02
